Help needed !
Have a 77 stag which after a lay up cut out after less than a one mile journey and would not restart , fiddled with all the usual connections for a about 20mins and eventually restarted to limp home the same short distance to home and again cut out . replaced ht leads /cap and plugs , replace ign coil with intermotor 11070 , cleaned starter motor connections which were corroded , checked and cleaned intertia switch and lumenition 3x pin connector , fuel pump working electronic type, alternator charging at 14.02 volts . will start from cold and warm up for 10-15 mins and cut out , usually after blipping throttle , try to restart long cranking but no firing , battery then fades , managed to restart with boost pack to battery but symptoms persist ? p.s base plate earth lead poor condition but intact not sure how crucial this is , need to change but someone has mullered the ba screws !! whats your thoughts guys ? Lloyd.
