Hello all,
My battery was dead, I charged it overnight,went for a run the next day,everything seemed rosy(voltmeter at 14,that is,l between 13 and 15!). But,the next day battery was dead again. I bought a new battery , removed the boot and the map reading bulb,and the same happened as above. I charged up the new one. Thinking there was a short somewhere I removed all the fuses from the fuse box. I then checked with a circuit tester to see if there was current flow between any of the terminals with the ignition off. What I found was no light on the tester whilst bridging the terminals but with the crocodile clip on the bottom terminal of fuse 1 "battery control" all the other top terminals lit up the light in the tester.
Should this happen ?.
Then still with all the fuses out I turned on the ignition and was surprised to see the ignition light and handbrake light on the cluster on. the electric windows also worked. But the biggest surprise was that the engine started the ignition light went out and ran fine although the rev counter didn't work.
If anybody is still reading
, is this normal and what could be running down the battery?
Al.
Al.
