Hi all,
is it correct that the pinion of the starter motor and the gearring on the flywheel are not lubricated (running dry)?
If so, is it advisable to smear some grease onto both teeth (as far as possible) when I install the new uprated starter motor as there is a new pinion running on an old --and I guess worn-- gear ring?
Hope you can help. Many thanks.
Klaus
Klaus
