When I picked up my 'new' Stag I checked the oil level before driving the 130 miles home but in my excitement I actually checked the auto box level. The vendor said it didn't use oil but added the rider that he hadn't used it a great deal which was borne out by the MOT's. It ran well and sounded great but when I checked the correct dipstick (yes, I know, there were 3 dipsticks in this story!) the oil appeared to be very low.
I topped it up and haven't done a huge mileage since but this weekend did a couple of hundred miles and I appear to be getting approx. 100 miles per litre.
There is some pale blueish smoke from the nearside exhaust and I can get a few microspots on my hand. Haven't noticed anything looking in the mirror through the rear hood window but the perspex gives a pale blue tinge anyway.
I'm fearful that I may need an engine rebuild though it does appear to run really nicely but I've no other Stag nearby to compare it with. I'm going to get a compression check done (I believe I should get it done both wet and dry) and see what that throws up. Sadly, I've used most of my budget buying the car so it's going to be a DIY affair I think.
I had thought that a bit of oil is a lot less expensive than a rebuild but it may not get through an MOT emissions test.
Any pointers? My thoughts are rings or guides
Andy
Andy
