Hpi checks
    Hpi checks
    Any recommendations on which company to use for a HPI check. There seem to be lots of companies out there at different prices? I just want an accurate check first time around.
    I used the AA, I would also get a MOT history on line, but this will only be from 2006.
      Hi I just text from my phone to 83600 it costs 3 pounds and is quite good you can pay a bit more for extra bits
      Gary
        Thanks. How do you check the mot history on line?
          Hi direct gov
          Cheers gary
            Check the MOT history of a vehicle from 2005 onwards, including if it passed or failed, its mileage and why it failed, download MOT test certificate
              I would use either Experian or HPi. Quite a few of the texting services use outdated/innacurate information.
              Kevin has a great link however. This to me is invaluable and gives you an idea of how the car was cared for and whether the garage rectified the failures (the latter is quite surprising).
              However, there is no substitute for checking the data that is tangible. A friend of mine once bought a cheap car. OK, the HPi he eventually did (for other reasons;read on) showed that his car was once a CAT D many years ago, but not the fact that the shell was from a car that should have been scrapped many moons ago. It is an easy enough mistake to make (I know that most people will not check this data). It could quite easily have not have been a CAT D, but simply a mangled shell which provided a willing identity for a seemingly scrapped car.
