Well the problem startedwhen I decided tore-veneer the dash (oak burr, looking very nice!), had to remove the choke cable to remove the wood. The cable was badly frayed and there is no waythey aregoing to thread back down thru the outers.
Why are the choke cables so expensive? I cannot believeit is not possibe to refit new cables into the choke pull. It appears that they are 'crimped' into place in 2 points so my plan is to drill thru the crimping remove the old cables, buy 2 metres of bowden cable (a couple of cycle back brake cables will do nicely). Then 'tin' the ends of the cables and slot them into the pull and solder thru the drilled holes. I used to solder nipples on brake cales in my old motorcycling days so soldering must be strong enough.
Anyone successfully fitted new cables to a choke pull?
- Alan
- Alan
