Zf bell housing to RV8
    Hi all,
    I have just got some enthusiasm to start back on the stag. I have just about finished the H4 head light upgrade and am now looking at the g/box mod from BW35 to ZF.
    I have an RV8 engine. I have an XJS ZF box with 35k miles on it. I have a range rover bell housing thanks to Jeff.
    Now I think I saw a post somewhere about this mod and someone said the BW35 bell housing could be used to fit the ZF box to the RV8 engine. Am I right or am I sadly deluded.
    No rude comments please as I am terribly sensitive.
    Regards to paul.
    paul
    i may be wrong but i thought the BW35 bell housing, was only for the triumph engine
    dave
      Dave.
      Ah yes you may be right. It may well just be for the Triumph engine..
      Paul
        Paul I'm pretty certain a ZF to RV8 is a piece of P**s using off the shelf parts. I'm sure someone can confirm this.
        Range Rover have RV8 mated to a ZF
          Originally posted by paul.twyman View Post
          Dave.
          Paul
          paul
          you said you have the range rover bell housing ,that will mate to your engine then you just need to make an adapter plate or sandwich plate to go between bell housing and zf box, i think ?
          dave
            Hi gents.. Yes it is all beginning to come back to me.
            I need to sort an adaptor plate. I seem to remember monarch do this sort of thing.
            My memory is not what it used to be. I will have a hunt around and see what the info is on the net.
            Thanks for you input.
              You don't need an adapter plate, as said above the ZF goes straight onto the RV8 just like it does on the Range Rover.
              You need to think about exactly which donor vehicle the ZF will come from, RR box is unsuitable for obvious reasons.
                paul
                dave
                No, as Ian said, the Range Rover bell housing already connects a ZF to a RV8 engine. From what I remember the ZF does not have a mechanical speedo drive but an electronic one so you will have to deal with that.
                  Paul.
                  My mk 1 had a rover engine with a Stag manual box and that needed an adaptor plate and as already said, the rover bell housing should mate to the ZF directly, (with my very limited mechanical knowledge).
                  Jeff.
                  Morning Julian.
                    Thanks gents,
                    I have a really bad memory and will get back into this in the next week or 2. I am away to the USA and when I get back I will get everything I need and then get the BW out..
                    Take care all
                      So what auto box was attached to the Rover V8 P5 and P6,I thought it was the BW 35
                      Sam
                        Sam
                        Probably was but with a different bell housing? I don't really know just guessing
                          HI Paul this site might be of help page 20 21 http://www.classicroverforum.net/vie...5069&start=300
                          Cheers Glenn
