A little while back, some of us discussed the difficulty in finding square sockets to fit male square plug heads. Someone kindly shared the info. about where 8 point sockets (which fit squares) can be bought from the USA which was helpful and I bought a set, I think there were 5 sizes included.
To add to that, and perhaps give more range or less time in obtaining them, Machine Mart are now advertising a set of 12 point 3/8" deep sockets (called 'multi-fit') at around a tenner. These will fit square heads and are easy to get, just be aware that as they have12 grooves they have less 'purchase' than the 8 point items, so siezed square plugs might get the corners rounded off.
Still, as often happens with me, the need is to make up a long tap wrench, and if you have 8 or 12 point sockets they allow you to use you ratchets and extensions as tap wrenches, especially if you wind some tape around the socket and tap to stop it sliding out.
