Stromberg overflow tube leaking fuel
    Driving the car on the weekend for a few miles, pulling up on the driveway, I checked under the bonnet and noticed a small drip of fuel from the fuel overflow tube at the front of the engine. I also noticed that the anti roll bar paint was pealing a little, so I think this has been happening for a while.
    Does anyone know what is likely to be causing this and how I can fix it?
    Thanks, Mark
    Hi Mark
    Usually a sticking needle valve in the carb,or float level too high causing the overflow..
    Sam
      Thanks Sam. the needles seem to be OK, so I will need to check the float height.
        Sam means the float needle valves not the needle in the piston. Confusing terminology I know, really they should be called simply float valves, except other than SU and Strombergs carbs, I don't think any other carb have a mixture needle..
          Ford VV, Keihin, Bing (BMW mcycle...).
            Ah, happy to stand corrected Russ.
              OK I understand, I looked it up in the manual. Thanks both.
              Mark
                Mikuni, Amel, must be more
                  I can remember Dellortos on bikes in my youth.
                    I had twin Dellortos on my Italian machine, Moto Rumi 125.
