Rear wing emblem
    Originally posted by 72BLUE View Post
    I thought the front/side indicator orange lens is one piece and convex? The one above is flat and in 2 pieces.
    Edit: As below.
    Keith
    On a closer look at the thumbnail the indicator is indeed in two pieces. Something more one has learnt.
    Rod
      No it is flat, the front indicator is domed.
      It has a light on when headlights are on (I presume like cruise lights) but no indicator.
      It still looks to me like the cruise lights without the badge but has anyone else got a clue????
      Northumberland
        Northumberland
        This is getting very confusing. from the picture you posted you have federal front side lamps fitted to the rear. All the lamps are the same size and shape as are the badges on our cars. so all interchangeable.
        Do you have a name BTW?
          Yes very confusing!
          I appear to have federal front cruise lights on the rear (flat two parts), with the bulb to the rear acting as a cruise light (not indicator) ie on with headlights.
          Unlikely to win any concours awards at Harrogate then!
          Northumberland (Martin)
            Yes very confusing!
            You got it Martin, If you can find some Red lenses for them then your sorted
              The 'STAG' badge is a separate item, only fitted to the 'Federal' Stags, but now available from some of the parts suppliers:
                Yes very confusing!
                An amber lens on the side of the car that comes on with the headlights, is that OK in the UK? I would have thought that would fail the MOT as it looks like an indicator but doesn't flash.
                1976 Triumph V8 Manual/OD in BRG
                  Volvo have been doing it for years - side marker lamps aren't statutary lighting so pretty sure exempt from MOT and most artics you see have amber side markers...
                    That makes sense .. Hadn't thought about the Artics you see amber light on the side.....
