Vacuum gauge
    Vacuum gauge
    Quick question
    I am going to look at a friends Stag who has a vacuum gauge fitted and he says its running in reverse. Is there just one tube from the inlet manifold or two to balance it? Where would it attach?
    Anyone got one who can tell me?
    I think its one of those gauges that has multi-coloured segments on it
    Andrew
    Andrew ,the ones I have fitted just have one vacuum pipe,can't imagine how it can go in reverse .he hasn't hooked it up to the exhaust has he Lol
    cheers Steve
      some vacuum gauges are set to work anti clockwise..... maybe that's seen as reverse.
        Thanks guy, I'll enjoy having a look now
          Originally posted by Andrew S View Post
          Quick question
          Andrew
          There is no point provided for attachment, and the distributor vacuum pipe is not suitable. But you could use the vacuum pipe that feeds the warm air flap motor (on the air filter).
            Thanks Chris
              If its a colored gauge then it will be clockwise
              normally they need a restictor in line
              connect to full vacuum not ported
              speedograph richfield sell the restictor
              Part No. MA Manifold Adaptor threaded 2BA for connecting vacuum gauge pipeline
              to inlet manifold. Supplied with blanking screw and built in restrictor.
              alan £3.14
                If you google images of vacuum gauges there are all sorts and more than I realized! Some work anti clockwise some work clockwise some work either side of centre.
                  also its not possible to run in reverse , there is a stop next to the needle and internally stopped as well
                  the mind boggles
                  alan
                    coloured anti clock wise
                    and another
                    and the other way
                      and another
                      and the other way
                      bet hes got the smiths coloured one
                      thats the one i know quite well
                      alan
                        I tapped the fitting into the head of the bolt for the banjo connection for the hose to the powerbrakes. Easy and removeable to do and no risk of drill swarf dropping into the inlet manifold.
                        Cheers Ian A
                          I also removed the power brake vacuum pipe and braised a 3/16 copper pipe into it.I fitted the vacumn gauge at the right side of the parcel tray so as not to be so intrusive.Easily seen from driver.Gauge works well.
                          Anthony
                            I fitted one once on my ford, drilled and tapped the inlet manifold - too many moons and Xmas puts to think about lol
                            Yes and it was the Lucas coloured one - it was great fun fitting gauges back then lol
                              So true, I remember transferring rev counters, voltmeters and oil pressure gauges from car to car. How things have changed.
