Just overhauling a RV8 engine that I intend to install in my stag. It's painted an orange colour that looks crap. Whats the best way to remove engine paint and whats the best way to make it look good. If engine paint is the answer, what colour's best.
Paint removal
Nitrmors isn't as strong as it used to be unless you can cling film it in so it doesn't dry out. M & M has had a terrible job getting it off the battery box.
I would try cellulose thinners with a brush, well ventilated and see if that pickles up the paint, also depends what paint but celly gets most off.
A dremel with a wire brush fitting might work.
I'd then go for a silver finish (to match the car), but there are a choice of engine paints, even RED! But then black would look good IMO.
Jeff.I only do what the voices in my wife’s head tell me to do!
In issue 207 of Classics Monthly there was a test of a number of paint strippers, might be worth a look if you can get your hands on a copy.
http://www.classicsmonthly.com/2013/...int-strippers/
Joakim
As one who used Nitromors last year in an attempt to remove the multiple layers of paint on my Stag I guess I come under the statement:
"That meant many brands had to re-formulate their products to comply and watch as forum trolls rubbished them in ignorance."
I followed the instructions to the letter, resorting to scoring through the layers to help the product penetrate and covering with cling-film to try and keep it from drying out. Evenleaving it all weekend, it barely softened the top layer of paint. Eventually resorted to the DA sander, covering the entire workshop, and everyone in it, in a fine layer of carmine red paint....
DT0051.jpgDT0056.jpgDave
Had another thought. How about taking it to a grit blaster or buy a small compressor and use a blasting gun, my local garage has one and that should work a treat as long as all the usual safety aspects are dealt with.
Being the engine, it won't distort like body panels.
There is also a mobile blasting company that I reckon could do it, so you may have one locally.
Just a thought.
Sorry, yes I did say a small compressor. It's because I have seen these guns supplied with compressors and as it's only for the engine, I thought it might do even if it took a month, lol.Originally posted by sad man View PostJeff, you need quite a large output compressor for even a small blaster, check the air requirement of the gun carefully, most 2hp compressor will not keep up without frequent stops. derekI only do what the voices in my wife’s head tell me to do!
I had the same problem with Nitromors, and like you Dave ended up using a DA, I also noticed that it doesn't burn on your skin like it used to either. Not that I recommend you try itOriginally posted by DJT View PostAs one who used Nitromors last year in an attempt to remove the multiple layers of paint on my Stag I guess I come under the statement:
[ATTACH=CONFIG]26745[/ATTACH][ATTACH=CONFIG]26746[/ATTACH]
Last edited by milothedog; 24 January 2014, 18:07.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
I'd rather it worked like it used to; I could wear gloves.......Originally posted by milothedog View PostI had the same problem with Nitromors, and like you Dave ended up using a DA, I also noticed that it doesn't burn on your skin like it used to either. Not that I recommend you try it
