Had a merry browse through the forum history for this one.. lots of posts about blocked/leaking water valves.. but nothing that quite matches the fun I've had this afternoon.
Put simply, my fan is unbelievably inefficient. All the controls work - if I select 'cold', I get cold air - if I select 'hot', I get (very) hot air. If I select 'screen', air comes out the screen vents.. if I select 'car', the footwell flap opens. Both fan speeds work.
(The vents in the middle of the dash don't work at all - I've no idea why and I can't figure out how to get that bit of the dash off without destroying it!)
What I'm trying to figure out is this - I have a 2500S as well, with what looks like exactly the same heater matrix, controls, and fan switch. So why do do the vents in the Stag only move enough air to barely tickle me, when the vents in the 2500 are powerful enough to remove hair?
Does the heater matrix itself have any filters on the air side that could've got blocked up? I poked about in the air intake, but aside from a couple of leaves it's kind of hard to tell what's going on down there!
