What on earth are these?
    Not seen these before, what are they?!!
    they go between t bar and b post of car
      they form the t bar cover to the same shape as b post,one hole is for bolt one is for wiring for interior light
        dave
        if you take your t-bar cover off, there at the ends where it meet the b-post
        dave
          .... and for the pedants, the two Stags I have bits from show that there are two different plates!! One side with two holes and one side with only the central hole. The cable loom to the T-Bar only passes through one of the B-Pillars. Obviously a period in history and a low production quantity of handmade items where an additional hole cost more than having to keep stocks of two different items!
            On all the cars I've worked on the T bar bolts directly to the top of ther B post, so these are some form of 'washer' then are they ? Are they metal ?
            Btw It is the right hand side that the three wires for the roof light come up, on mk 2 cars and if you're ever working on one, be aware that the black wire is not n earth, it is a 12v feed
              Thanks guys.
              I don't think I've got these on mine either, but I have never fully unbolted the T bar - only enough to change out the hard top rear window connectors!
