Why has my fuel tank got two breathers?
    Looking at the breather thread, and in my workshop manual, seems the breather to the fuel tank goes up a pipe, through a fuel filter then connects to the side of the chrome filler cap.
    On my tank however, and not illustrated in the manual, next to my fuel level sender, I have the half inch diameter pipe that joins onto the side of the filler neck hose, but in addition, next to this, I also have a pipe that is perhaps 1/4 inch, just a couple of inches long, that connected to a plastic pipe that went straight out the boot floor with no filter, and it wasn't even raised so I wonder how much fuel I lost if I ever filled the tank to a higher level?
    Is this extra breather tube standard?, or should I block it off?
    To use it would mean I really should have two raised filters!
    Pete
    This is a fuel return stub for PI cars and should be blanked off on your Stag, use some hose and a bolt.
      Cheers Ian.
      Does this mean I have a Saloon tank or did Triumph fit the same tank to both cars?
        Originally posted by Nambo View Post
        Cheers Ian.
        The tank is common with the 2000/2500 Estates, some of which were 2.5Pi's
          Cheers Ian.
          An estate possibly-a saloon no they were different and fitted behind the rear seat sitting upright.
            Cheers Ian.
            Same part no's for the Stag and 2000/2500 Saloons fuel tank 312402
            1976 Triumph V8 Manual/OD in BRG
              Does this mean everybody else has the extra but blanked off breather tube on their Staag?
                Oh yes
                  Originally posted by jleyton View Post
                  Oh yes
                  Not necessarily, if you bought a remanufactured tank from RB then it doesn't come with the additional pipework.
                    Fair point - but that's not a 'real' one
                      rac is correct the saloon tank is not same as stag as it is rectangular in shape and sits upright at the back of rear seat I believe the estate tank is like stag tank
