The luminition electronic ignition failed on our MK 11 original triumph V8 engine. I fitted an ACCUSPARK electronic ignition and I have the following problem or problems.
Timing the ignition by the lamp method as per the ACCUSPARK method, which differs from the triumph R O M method in as much as you connect the lamp to the negative coil connection and battery negative terminal.
With the # 2 piston at 12 degrees BTDC I expected to see the lamp light momentarily at 12 degrees BTDC and remain unlit for the remaining 78 degrees of the quarter turn and repeat thereafter at each quarter turn of the shaft.
I contacted ACCUSPARK re the above. They informed me the unit was working. They didn't comment on the operation of the lamp.
Positioning the coil lead and a plug lead to earth in turn I get a healthy spark, starter cranking the engine. Repeating the above and hand cranking the engine I get no spark. I have in the past got a spark hand cranking when the luminition system was working.
The coil, dis cap and rotor arm are new, the carbs have been competently overhauled. The alternator is electrically connected but not being driven.
The engine spins merrily on the starter with no sign of firing using "easi start" or petrol. Not even a little back fire or splutter.
I'm confident the collective knowledge of fellow club members will be able to tell me what the problem or problems are.
I'm seriously considering regressing to the two points system.
I'm open to all remedies short of employing a box of matches.
Cheers to all. I live in hopes. At least we're not flooded out.
Georegstag1.
Georegstag1.
