At the moment Colonel Mustard (my Mk 1 Stag) is up on axle stands with the gearbox removed...new clutch going in soon. Whilst under there I am trying to catch up on a few jobs that need doing. One of which is the final drive which leaks oil from the seals. When I check the oil level I can hear air escaping from the unit as the plug comes out...so I'm pretty sure that the breather is blocked. There's nothing in the workshop manual about it but I can feel something on the upper right corner of the diff backplate. I assume that this is the breather? How do you check and clear it? Do I need to remove the backplate?
Chris
Chris
