Evening all,
Broke down yesterday and had to call the RAC out due to Holly carb not functioning, i.e. would not start. Those of you who have got Holly carbs, have you had this problem? The Holly carb is a 390, standard plate - both purchased from Tony Hart. Have not got a 7 degree adaptor plate on and I wonder if this will help the situation. It seems that I have got 'heat soak' [if that is the correct phrase]; has anyone tried to insulate the carb to stop the 'heat soak'. I have also got stainless steel tubular manifolds, Holly fuel pump and regulator. Any help/advice would be appreciated in this matter. Many thanks.
[If I don't reply to any response it is not that I am being rude but I have to get up very early in the morning, i.e. 2.30 am] Mike
