When we first got our Stag, I noticed quite a bit of play on both front wheel bearings. This wasn’t apparent when driving, the car was very stable even at high speeds (I drove +100miles highway when bringing her home). But I could feel and hear the bearings move when inspecting the car on the lift. Because of the low cost I immediately replaced them with 2 new sets.
Yesterday I again had the Stag on the lift (chasing a small oil leak) and on a hunch checked the bearings again. Although not as bad as at first, the left front does have play once again, after only about 1000km. I thought maybe the bearings had settled or the races hadn’t been seated properly, so tried to adjust. I can get the wheel to turn smoothly and without play, but I cannot lock the castellated nut in that position. When slacked off to the previous (as per the ROM), there is some of play. When I tighten it to the next position, I feel there is too much resistance. With only 5 positions, the adjustment isn’t very fine in my opinion. How much play is acceptable? Most previous vehicles I worked on (Land Rover, Lotus, VW) always had to be set up with no noticeable play, but I remember the pre-assembled bearings for my Ifor Williams cartrailer also had a bit of play when cold.
Any advice welcome!
Thanks,
Filip
Any advice welcome!
Thanks,
Filip
