Having spent quite a lot of time refurbishing my Strom's as well as fitting the HRS uprated needles I decided to have another attack at the Holley set up.
I always had a catch tank when I had the Holley before but never a PCV valve fitted so, this was the final part of the breathing system I had to deal with.
All now sorted, I have used a Fram PCV valve for which I cut a hole almost the exact diameter of the valve (19.5 mm) into the original catch tank and sealed it in place with silicone. All I did then was to take the outlet from the PCV valve to the PCV inlet on the Holley using fuel pipe.
It works beautifully with none of the original slight oily smell at idle from the previous vent from the CT into the air filter.
Total cost of parts about £25.00 for the CT and PCV valve combined and another £3.00 for the cutter which I bough on ebay from a very good tool supplier called Bositools based in Ilford.
Pictures of the set-up are in my albums.
While this is used for the Holley I see no reason at all why it would not work for the Weber too but others may say different.
I'm keeping the Holley now too - it is just so much simpler to set-up and looks a lot neater too IMHO.
Cheers!
Cheers!
Graham
