Manual Gearbox reconditioner
    Gents,
    I'm still trying to get the dimensions I need to install the Stag internals into a saloon box. Does anyone know of a friendly Stag gearbox reconditioner that may be able to help me?
    thanks in advance,
    Raoul
    you want stag shafts and gears in a saloon casing?
    I think the bearing sizes are different to start with, i.e. smaller bearings for the saloon box.
    why are you doing this? if you have a good saloon box, why not keep it as is and play with the diff perhaps.
    I have no idea what the ratio differences are between stag and saloon box. or even if the input shaft of a saloon would reach the flywheel, nor what you might need to do with the prop
    rambling
    sorry
    please hold caller somebody who knows will be along shortly
      Hi Richard,
      Stag manual bows are like hens teeth over here, I have all the internals from a Stag box, and I have a saloon case, the only differences are the lay shaft is a different diameter and the distance between the thrust washers is larger, there fore I need someone to measure those on a genuine gearbox. I'm told there is a guy who advertises in the UK SOC mag that reconditions Stag boxes and need his contact details.
      thanks,
      Raoul
        Dave at overdrive spares was helpfull when i had a problem with my OD and they also rebuild gearboxs,worth a call http://www.odspares.com/
        Cheers Steve
          Thanks Steve!
