Hope someone can help. To celebrate rebuilding the steering rack and fitting the new Weber vacuum tank I took the stag for a test drive. within 6 miles the temp guage was over half way, in another mile was in the red. I've never had these problems before. The Kenlowe dutifully kicked in but didn't help. I drained the sytem. flushed it and fitted a new 88 thermostat. Still overheating. I had topped up with BP 97 thinking it was that burning to hot. Drained fuel and replaced with 95 still overheating. I had a new 12 vane pump from Rimmers fitted about 5 years ago. Hope it isn't that but can't think what else it can be. Any advice greatly appreciated. Mike
Over heating possible water pump fail.
Has this suddenly come on? What temperature does she usually run at? Is there water coming out of the overflow bottle? Does the engine really feel hot when you lean over the engine compartment? I say this in case the temp sensor is failing and over reading. Thinking aloud here but I am sure others will have other suggestions tooYellow Rules OK
See if you can get hold of an infra-red thermometer, (one of these gun type things). Then you can check the temperature of various things to see if it really is getting hot, or the gauge is reading high.
Could the fuel gauge also be reading high? It uses the same voltage stabiliser as the temperature gauge does.
Mike.Mine since 1987. Finished a 20+ year rebuild in 2012. One of many Triumphs and a 1949 LandRover!
Originally posted by Mike J View PostPipes to and from rad not as hot as I would expect
As even with no pumping flow the top pipe would get too hot to hold through convection alone ?Last edited by Paul Goldsmith; 13 March 2014, 18:34.
Checked the thermostat before fitting. Just been out in it again. Temp fluctuates. Almost going into the red then slipping back to vertical. There is intermitent flow looking into the top of the rad. I wonder if the 12 vane conversion (5 years ago by the engine rebuilders) used the correct housing and over time the nut on top of the pump has slackened. Not sure as never worked on this type of pump before. Paul the sender is about 2 yrs old and has been checked. Mike
