So I put petrol in it today and for the first time in five years heard my Stag running, started quite easily and no smoke or vapour from the exhaust.
I adjusted the ignition timing and noted in the book that you have to pull the pipe off the Vacuum advance, which I did, my question though is why?, for at tickover, the timing marks didnt move whether I had the pipe connected or not, it only showed a difference when I revved the engine, does this indicate a problem with my vacuum advance?
The other question, I have a fuel ratio meter, now the instructions say the ratio should be around 14.7 to 1
Now is this just for modern vehicles?, what ratio should the Stag run on?, I used to think back in the day the ratio was 16 to 1, though that is even leaner.
