Hello - need some information and help
I have rebuilt my engine (TV8) and primed the oil pump.
After the pump had picked up oil and stated to feed the right hand cylinder head, the oil pressure relief valve let go and squirted out a quantity of oil into my carefully positioned drip tray.
what i am more concerned about is the fact that regardless of where the engine was rotated to no oil flowed through to the LH cylinder head, each time i pumped oil it flowed to the RH cylinder head and also the pressure relief valve opened.
I removed the LH cylinder head and checked that the oil feed from the jack shaft was clear, which it was. with the LH timing chain removed i can rotate the jack shaft and feel it through the oil way.
the jack shaft is original and in very good condition.
I rebuilt the oil pump and the pressure relief valve so i am happy with this.
How is oil supposed to get to the LH cylinder head and what is the design philosophy for this ?
any thoughts on this, thanks in advance
