Question for you autobox experts on here, perhaps i'm looking at something which is normal. At rest the kickdown cable crimp is just off the adjuster but after running the engine or operating the throttle manually the cable seems to stick with the crimp resting about 3/4 inch away,i can manually push the cam/cable back to it's original position as though there should be some sort of return spring somewhere-have tried with a temp spring and is quite easy to get it to return. Haven't been able to go out on the road yet to try it(waiting for my free tax!) but the car moves back and forth ok.
Is this normal-does the cable return with oil pressure in the box?--Have disconnected the cable and pulled it in/out of the gearbox easily.
views/opinions greatly appreciated.
Rob.
Rob.
