space behind the settee, and water leak on inlet & jobs done
    Managed to remove the front bumper from behind the settee and fitted it today, warmed up the old girl , not 'M', the stag, inlet manifold started leaking , ok when hot but weeping from nearside rear by the dizzy, will remove dizzy and give the bolts a tweak. trying to get ready for Tuesday.
    Jobs completed this winter:-
    Battery box area painted body colour, power steering pump painted and bracket powder coated, viscous fan coupling changed, electric fan fitted, header tank fitted with level switch warning light, gearbox oil cooler fins straightened and painted, bw35 gearbox sump gasket changed, cross shaft seals changed, dowtey seals fitted to dip stick tube, engine oil pump seals changed and pump checked, front rad support panel painted and chip guarded, wiper motor park switch repaired, driver side wheel box seals replaced, LED front side lights fitted (Thanks Andrew),near side wheel bearing adjusted and bottom ball joint boot changed, bonnet insulation pad retainers engraved with stag logo's,
    hopefully a run out Tuesday
    P.S Don't forget your MUM tomorrow
