Hi
I have an intermittent fuse issue caused by either one of my dashboard displays / lights or my left hand front / rear side lights. Basically the 10A fuse number 7/8is the one that is blowing. I originally thought this was a poor earth in the rear light cluster. Have since sorted both LH and RH side (as per previous post).
I replace the fuse but it does not immediately blow so is there a way / procedure for identifying exactly what is causing it to blow. Do I disconnect each dash board dial / display (temp gauge / volts / fuel / speedo / rev counter / oil pressure) in turn or is there likely to be an offending item to start with?
If anyone has a few suggestions or things I can note that would be helpful. Not even sure if it is not to do with the fuse board or connectors moving when going over a speed bump - but don't wish to try to replicate this in order to find the fault.
Brake lights are working by the way.
Here is the circuit diagram I am looking at + some dash board photos.
Cheers Jonathan
Cheers Jonathan
