What is this pipe?
    What is this pipe?
    Can anyone help, found this pipe which comes out it the transmission tunnel, i've blown in it and there appears to be back pressure, i'm wondering if it could be an old fuel pipe, but before I investigate I was wondering if anybody knew, cheers[ATTACH=CONFIG]27906
    Assuming you have a BW35 gearbox, it is the breather pipe. Should be draped over the servo and into the wing cavity.
      It is a bw35 gearbox and it makes total sense, another job sorted, many thanks dave.
        I would suggest this pipe is extended to a suitable point below the car where it will do no harm as the bw35 is renown to spit out fluid and I for one do not want that fluid on the inside of a wing . Hydralic fluid will strip paint and cause corrosion to area .
        Cheers Glenn
