Afternoon all
Let me acknowledge that some may say that adding a amplifier to the Stag seems a little crazy given the gorgeous sound it makes, however I am trying to do away with a modern head unit ( which has the usual amplification built in ) and therefore I need a seperate amp, which I will probably mount in the boot which will drive the speakers. Is there anywhere in the rear of the car that I could take this feed from ? Im guessing not, so the second option in my mind would be to take a feed from the fuse box and perhaps install a new fuse dedicated to this feed - is that possible and if so how difficult is it ? And could this feed be switched so its only powered when the ignition is at least turned to the accessories option ? Many thanks in advance
The manual for the amplifier says
FUSE REQUIREMENTS
It is absolutely vital that the main power wire(s)
to the amplifier(s) in the system be fused within
18 inches (45 cm) of the positive battery post
connection.The fuse value at each power wire
should be high enough for all of the equipment
being run from that power wire. If only the
e4300 is being run from that power wire, we
recommend a 40A fuse be used.AGU (big glass
fuse) or MaxiFuse™ (big plastic-body fuse) types
are recommended.
No fuse is required or recommended directly
before the amplifier power connection. If one is
desired, we recommend the use of a 40A AGU fuse
or MaxiFuse™ type.
FUSE REQUIREMENTS
are recommended.
or MaxiFuse™ type.
