Hi, I need help and advice I have been told/seen on net if I want to use MSD atomic fuel injunction I we'll need a manifold for the 4 barrel Holley type carb, so then MSD fuel injunction bolts straight on. Any information or phone numbers will help. Templar
MSD atomic fuel injection
As Glenn says looks like you will need a four barrel adaptor,after all that money you will still have the old inlet manifold in the way of airflow and fuel being injected way back up the inlet tracks though.If your looking for smooth running it could be the ticket if your looking for power gains it probably won't do much more than a carb.imo
Cheers Steve
Originally posted by Seaking View PostHi Templar
Looking at the site i believe what is required is the 7 degree adapter plate for the holly see ebay Item: 351042059996
Then yes i Believe the Msd will bolt on.
Cheers Glenn
Cheers Steve
Originally posted by Stagdad View Posthttp://msdignition.shptron.com/p/ato...aster-kit?pp=8
Cheers Steve
NeilNeil
msd attomioc fuel injection
Originally posted by KOY 23 View PostAn option is to use the EFI from Patton machine www.pattonmachine.com, this uses the Strombergs as throttle bodies and has been used on TR's and Stags. Will save you messing around with adaptors.
John.
