My '76 Stag has covered only 35k miles since new and presents the following:
1. Excessive play in R/N/S bearings.
2. Occasional grabbing of rear brake(s)
3. Leaking diff.
I recently removed the R/N/S brake drum to reveal a seized wheel cylinder and hand brake mechanism. It was evident that this was the first time that the drum had been removed.
The car passed its MOT in July with only comment of wheel bearing play.
In anticipation of having to repair both sides I have purchased a reconditioned half shaft from Fitchetts to address the bearing play (I don't want to get involved with 100 ton presses), replacement wheel cylinders, handbrake levers, 12 x new nyloc nuts for the bearing housing to trailing arms, lever boots and handbrake cable. I also intend to grease the splines on the R/O/S half shaft and have bought a replacement spline boot. I have also bought a new handbrake cable with attachments.
I am torn between "if it ain't broke don't fix it" and the "do it all right first time at the same time" positions.
You have guessed that I am torn between doing each side independently or dropping the whole shooting match and refurbing the whole assembly to a standard which I have admired on attached photos on the Forum.
My limitations are that I am working in a single garage with a single parking space, my physical strength and flexibility is diminished by a recent operation and I live in rural Shropshire, many miles from classic civilisation. I am confident of tackling the change of half shaft and wheel cylinders BUT is the dropping of assembly that much more of a task? I have trolley jacks, wheel chocks etc.
As always, ALL comments and advice gratefully received.
3. Leaking diff.
