Auto shift Handel
    Auto shift Handel
    Does anyone know how you remove this from the shaft, the T bit I've tried most things, don't want to put much pressure on it in case I damage it all. I thought that it would simply unscrew, but have been unsuccessful. Any help suggestions greatfully received.
    Thanks.
    Duncan.
    Hi Duncan
    from memory as I am away at the moment isn't there a small grub screw at the rear of the handle which locks it in place ?
    i know I took mine off to refit the interior without any issue
    ill have a look tonight of no one else comes along with the answer
    cheers glyn
      Thanks that would help.
      Duncan
        Not a grub screw, just a hole. Get an Allen key which is a snug fit in the hole and put the short end in. Hold the collar steady and unscrew the T-handle. Make sure it is a good quality Allen key, not one left over from assembling flat-pack furniture.......
          I removed mine yesterday it was tight but I just turned it anti clockwise and it unscrewed but I did have to use quiet a bit of force
