Hi to all the RV8 owners out there.
Have been out on my maiden voyage today and am generally ok with it apart from fuel leaking from one carb overflow and an annoying drumming vibration at certain revs. Checked exhaust system and found the link pipes fouling where they go through the rear arms, adjusted these and it is much better but still some drumming. Gave it a good coat of looking over underneath and noticed the sump is touching the steering rack so think this is the problem.(conversion done by another not me so looks to have been like this some time!)anyone else had this, how did you overcome it? seem to recall reading sometime about spacers on the crossmember which doesn't look too easy with everything in situ as well as I suspect throwing the wheel alignment out which I have just had done.is it possible I thought to just lower the rack slightly by adjusting the mounting holes-just a thought.
any thoughts/suggestions greatly appreciated.
cheers Rob.
cheers Rob.
