Suspension straps
    Suspension straps
    Got a new R/H rear suspension to body strap from JP, as mine was a bit bent, but when I tried to fit it, it looked more like the left side,(which is also a bit distorted) phoned JP but had know idea. Has anyone experienced the same problem? + Does anyone have a picture? As the manuals are not very clear.
    They are deliberately bent at an odd angle but I fitted the wrong side to a car a while ago and was scratching my head for a while until I'd relised what I'd done.
    Can you compare your new one to the old one and! if you're sure it's wrong, ask Paddocks to compare the two sides ?
    Gooid luck.
      Cheers Julian I have fitted the so called r/h strap to the left side,and it seems to fit, but its not quit the same, i put it down to remanufactured parts.
