I braved the rain today to change my LH outer driveshaft, as it was making a squoink noise under braking (the inner bearing race I suspect is moving on the flange in sympathy with the warped drum mounting flange where someone has taken a hammer to it in the past).
I noticed that the sliding spline had gone dry again, and random muffled clonks from the rear end on reversing, and worsening Triumph twitch told me something needed to be done.........and more permanent than just giving it a good smear before re-assembly.
So I took off both inner yokes, and drilled the spline sleeves 5.5mm at the UJ end on the external shoulder, tapped them 1/4 UNF and fitted grease nipples. Reassembled the yokes to the car, but before bolting them up, left the bolts very slack so the flanges were located,and compressed the sliding spline as much as I could.
I then got an old grease gun, filled it with CV grease and pumped it in until the shaft flanges were pushed back on to the diff flanges again, and then a few more strokes until I saw the spline bellows just start to inflate.
Tightened everything back up, and took it for a run and it was transformed, with no detectable twitch, and my reversing thuds and clonks eliminated.
It may not be the dogs testes Datsun shafts, but it was a very cheap and effective mod that I thought a couple of you might like to do....... plus I can grease my splines easily should I get any twitch later
Russ:dude:
Russ:dude:
