We have all heard of the saga of waper pump shaft gears failing due to 'soft' gear teeth. Some of you will recall I had the same problem recently. I have a selection of waterpumps from different TR7, Sprint and Stag engines and I compared the shafts. All but one had the spiral grooves continuing up past the gear teeth with the groove finishing in a rounded end. Just one had the grooves continuing past the teeth and then gradually shallowing to nothing.
Myfailed shaft was the odd one out. Doing some trawling thru the stagdigest.net archive I came across this posting
Re: water thrower for water pump
Posted by: kenhockey (IP Logged)
Date: May 07, 2007 09:39AM
I don't know if this helps, but the water pump shafts I have had trouble with seem to be the ones where that grooving above the drive gear tapers off - the ones where the grooves are the same depth all the way I have used with no drama, but no guarantee I suppose - I guess they were hardened in batches and that may be where the problems lie.
Interesting to see Ken reached the same conclusion.
So if you have to fit a new pumpshaft it would seem a good idea not to fit the shaft with the 'tapered grooves'
- Alan
- Alan
