Hi,
I have a Stag and since Feb 12 have been doing it up - mainly bodywork and getting it on the road. Since passing the mot, daily running issues are plaguing me.
I've got problems getting the V8 engine revving properly. As soon I put any real pressure on the accelerator, the engine stalls or drops in revs. Pulling out the choke seems to always aid the engine picking up but struggles to idle equally without. Warming up is a problem, backfiring is frequent and the choke doesn't appear to help that much though without it, the engine simply doesnt run. I can seemingly 'build' revs by working up the pressure on the foot pedal. Once revs are built the engine feels like its pulling back on itself as though it is saying no I dont want to go.
I have been having carb problems though I thought I'd sorted these. I took off the main throttle linkage to do the haynes carb setting up exercise and the engine simply stopped. Trying to get the engine to run evenly without the linkage is a major headache. I have got it better but the idle running screws needed to be turned in quite a few times and by hand revving the RH carb revs freely but the LH seems to hold back. If I have isolated this to the LH bank - what would be causing it to hold back and not rev freely?
I'll come back to the auto transmission leak, pdwa brake fluid leak and the auto transmission leak in separate posts!!
Feeling flustered!!
Any help from the Forum's seasoned experts would be gratefully received!
Feeling flustered!!
