Hi
I've just been fiddling with my Stag following some advice with my carbs, when I noticed a knocking noise coming from the water pump area when the engine is idling. Would anyone know if this is likely to be the water pump bearings? The noise seems to go when the engine is revved up. Should I be worried?? Sorry to be asking so many questions on here but I'm still relatively new to Stag ownership!! Thanks! (again)
I think I mangled one thread when I put the manifold back on though
If it has to come off agan I'll definately be drilling bigger holes in it. The fact that somebody previously had been hitting it on the long bolt holes did not help- it is one of theses I mangled, though it tightened Ok. There is still a slight noise from the pump but not the heavy knocking which was there. I suspect that my alternator bearings are adding to it a little!!
