Apologies if this has been covered several times before, but there were manymany cooling related posts, none of which seem to cover the issue precisely.
Had my Stag for coming up to a year now. Love it. Never seen the temp needle go past half way, and I use it daily.
A month or so ago, it started going through water and when taking the top off the expansion tank bottle when cold after a refill and a drive, the water level was right to the top.
The problem later manifested itself as a leaky radiator, so replaced the radiator and hoses and gave it all a good flush out. The temp remains under 90, and have been gradually topping up the water level as the air is expelled from the system. No sign of leaks.
Went to check the water today (stone cold engine), and there was a big gurgle when removing the expansion tank cap, followed by water shooting out the overflow hole in the tank.
What does this mean?
As I say, no overheating, no leaks that I can see, no water in the vee (but quite a bit of oil), no mayo on the oil filler cap and no streaks on the dipstick. Is it just something stupid like a worn cap?
Any guidance much appreciated!
