Alastair,
From your earlier post it seemed you had no spark. Is that still the case? It makes a huge difference to diagnosis!
If you still have no spark that's the route you need to follow. If you have a spark and overly rich mixture then I'd go with Neil's suggestion, a sticky float valve could easily be the cause. Too much fuel going itno the engine puts the fire out, and fits in with those sooty plugs.
Good Luck
Good Luck
