Originally posted by pitzey
View Post
Front Grill
This topic is closed.
So now I have actually managed to start this, I have noticed that there is some sort of groove cut on one side of the fins. I assume this is some sort of drip strip and should be underneath the fin. Mine were a mixture, at least two of them had the groove on the top, which I think would catch water and therefore promote corrosion. Would that be right, under rather than on top ??
Originally posted by Omen View PostSo now I have actually managed to start this, I have noticed that there is some sort of groove cut on one side of the fins. I assume this is some sort of drip strip and should be underneath the fin. Mine were a mixture, at least two of them had the groove on the top, which I think would catch water and therefore promote corrosion. Would that be right, under rather than on top ??
Basically you are correct groove & lip to the bottom. On my car some one had fitted two left hand pieces - they simply turned one upside and fitted it to the right hand side. Looked ok from a distance but the spacing between the "slats" is slightly different top and bottom. Managed to obtain a good right hand side one the complete the set.
RogerNow Stagless but have numerous car projects
So many cars, so little time!
