Has anyone got a picture of where the petrol pipe goes after it has gone trough the hole in the boot floor ,It seems how ever many pictures you take when striping the car you never seen to take the one you need .this is mine at the moment but this cant be right If you click on the picture on the right you can see it hanging down WP_20140526_002.jpgWP_20140526_004.jpg
petrol pipe run under car
It is plastic and goes out from the pump behind the tank ( shoud be 2 clips on the rear wall of the boot) through the top of the 2 hole on the left (nearside) rear wall. goes up and over the arch ( should see some holes for the clips ) still looking forward bends right and joins the metal pipe that just bends around the left side of the tunnel. Again you should see holes for the clips. Mine has double clips fuel and brakeline. Runs down the left side of the tunnel then bend up about 6" into the engine bay where it becomes plastic until 8" from the filter where its braided fuel pipe.
Hope that makes sense.
Hope that makes sense.[/QUOTE]
Thanks Malc all makes sense but cant find the holes for clips where it goes over the arch .....must be missing something will look again
JohnMK 2 1977 FLAMENCO RED ,WEBER ,BELT DRIVEN WATER PUMP.
