LED Indicator lights
    Has anyone replaced their indicator bulbs with LEDs? I'm sure my originals aren't that bright and would like to improve them. Any tips?
    Keith
    Not done this but did put LED bulbs in brake/ rear lights. Did not think any improvement so removed them. The way to go is to put chrome tape around the interior bowl of rear light unit.( Just plucking up the courage in my case to disturb lens etc for fear of breaking off location tabs!)
      I used 'chrome' aerosol paint out of halfords, worked a treat.
        Not sure if this will help you but I submitted this article to magazine a long time ago
        Lens article.pdf
          make sure your earths are good I would suggest. you cannot have enough earth connections
          Also the bulb holders can become less effective, rather than new replacements I found I could take the original items apart. the forks and the bayonet holder are two seperate parts that are held together by the plastic cover. carefully lever the plastic back and you should be able to get the fork bit off, clean up the surfaces and add a little electrical cleaner and then reassemble. I was quite impressed with the difference if I may be so bold.
          Also if your car is mid'ish 73 or earlier you may have the dreaded nighttime dimming relay. it is a yellow box of joy fitted over the nearside inner wheel arch. access it via the boot. remove, splice the same coloured wires together and you should have brighter brake lights when the headlights are on also.
