Engine Turning
    Engine Turning
    Hi All,
    Sorry for basic question (again) - what is the best way of turning the engine manually for setting points gaps etc ? My car is an auto so I can't put it in gear and slowly push the car to get the correct position for points setting and there doesn't seem to be a readily accessible crankshaft pulley nut to get a spanner around....
    Any ideas would be most welcome.
    Thanks,
    Andy
    Andy
    Take 1 bolt out of the timing marker quadrant on the front cover and swivel it to one side, then you need to fit a pr of 18" stillsons on the shaft behind the pulleys.
    Bob
      Thanks Bob - will give it a try - much appreciated.
        or fit electronic ignition even easier ..............the best thing I ever did
        JOHN
          24mm i think spanner on the fly wheel bolt care should be taken not to damage radiator.
          rgds Nick
            Thanks all !
