Overdrive inhibitor switch
    Are you sure the wire doesn't go to the solenoid
      Hi Malc,
      The solenoid has both wires attached. Ignition on, third or fourth selected - no click from solenoid. The problem is either the solenoid or the inhibitor switch. And the fact I have a loose wire on the near side in the general area, leads me to believe that it's the inhibitor switch. I just can't get to the bl**dy thing!
      Any tips/hints gratefully accepted!
      Thanks,
      Jon
        Jon
        I've been down this road and I was able to access the inhibitor switch in the top of the gearbox through the gearstick hole. It is a B**CH. After all that AND completely re-wring the power feed direct from the fuse box I found the problem to be the NEW gear knob switch. It's very easy for it to short out in the gear knob - kept blowing the fuse on mine. The connections to the gear knob switch are just a poor design. I wish I could find a better gear knob switch as I've the exact same issue with my MGB.
        Nick
        Nick
          Nick,
          Thanks for the info! Did you manage to get to the switch without lowering anything? I don't think my hands are small enough to squeeze between the transmission tunnel and the gearbox!
          Cheers!
          Jon
            Originally posted by jleyton View Post
            Unless I'm misreading everything (quite likely ) you're referring to removing the overdrive solenoid, whereas the thread is about removing the inhibitor switch
            Juliuan
            Ah ha you spotted my Gin consumption, still at least I can spoll my name
            Now I understand why folk are talking about dropping the box less gin tonight
              Originally posted by jonnygangsta View Post
              Nick,
              Cheers!
              Jon
              Hi Jon,
              I was underneath a Stag on a ramp today and I tried to see if I could reach that inhibitor switch. The good news is that I could
              It did have the exhausts and prop shaft off and I didn't notice if their presence would have made it any harder, however I'd rather drop a prop shaft or exhaust than a gearbox
              Anyway, if you've got a friendly garage with a ramp nearby then you should be able to check it out.
              Cheera
                Jon
                Gearbox wasn't lowered.I could get at the wires but I wasn't able to unscrew and remove the switch.
                Nick
                Nick
                  Julian, Nick,
                  Thanks to you both for the info. I will set aside a couple of hours on Saturday, it's supposed to be raining ��, and report back on my progress!
                  Jon
