After a few miles and at tickover both lights begin to dimly light up. Loose wire or ????
oil and brake light
Hi I had the same with mine and it turned out that the bottom end needed rebuilding I hope your is something easier and cheaper. Have you got an oil pressure gauge fitted? I fitted one once I noticed the lights glowing and discovered that once the engine was warm the oil pressure dropped considerably almost to nothing.
Good luck
Simon
Originally posted by malc4d View PostAfter a few miles and at tickover both lights begin to dimly light up. Loose wire or ????
Before resorting to despair, it is totally worth connecting a calibrated mechanical oil pressure gauge to see what is really going on.
Could be a variety of things, including a failing oil pressure switch. Or a sticky oil pressure relief valve. Or incorrectly assembled internals in the canister oil filter assembly, and so on. Or the worn oil pump already mentioned.
Low oil pressure CAN be due to worn crank bearings, but it can also be due to a lot of other things. Absolute first priority must be to establish what pressure you actually have.Header tanks - you can't beat a bit of bling.
Agree with Wilf - those pressure switches have a common failure mode that makes them come on at higher and higher pressures! A check of the actual oil pressure is the first thing to do.
Mike.Mine since 1987. Finished a 20+ year rebuild in 2012. One of many Triumphs and a 1949 LandRover!
