Hi All
Some of you may have seen comments made by me and responded to by others regarding Standard (ROLON) vs German (JWIS) chains.
By a coincidence I found the original set of German chains in my man cave, they were fitted June 1994 just after I first bought my car and covered 2600miles before I had to rebuild the engine. They were dispatched to the man cave because I was told that they could snap without warning, whether true or not I have run for over 30k miles on standard chains.
Chronology of Chain work on my engine is as follows;
June 1994 - 94,000 miles - fitted JWIS Chains, standard sprockets, guides and tensioners. To replace rattly standard chains, I recall that the sprockets taken off the engine were like vampire teeth, didn't keep them!
May 1996 - 96,600 miles - rebuilt engine, fitted new standard chains - on specialist advice, reused the tensioners, guides and sprockets. - probably against specialist advise because he wanted to sell me new
May 2002 - 108,000 miles - chains rattling IIRC long chain had stretched and hydraulic tensioner was extended. I binned them at the time I guess, cant find them but then I haven't been right through the garage yet
June 2013 - 127,000 miles - rebuilt engine again (started out as HGF ended up finding out that a certain supplier sells hardened cranks that aint), replaced chains, guides, tensioners and crank sprockets (sprockets because of my hamfistery with a slide hammer rather than anything else). The others were in good condition.
So in a nutshell
JWIS chains in the photos that follow covered just 2,600miles
ROLON chains in the photos that follow covered 19,000miles and did NOT rattle, the pic of the tensioners when fitted show the short chain to be good, the long chain was extended because I bent the cam sprocket support when jacking the LH head off broken studs. I have no reason to believe that the tensioner would have been out any further than the short chain.
Crank sprockets, tensioners and guides in the photos that were all fitted in June 1994 and had covered 33,000 miles, 2,600 miles with JWIS chains and 30,000 miles with standard ROLON chains
The worst guide was the quarter moon shaped one, tramlines were just under 1mm deep. The other guides, especially the flat guides had only light wear on the leading edge. I might have used them again and might yet if quality issues with 21st century items are proven!
The Tensioners were the worst, the tramlines are 2mm deep.
pics to follow.......
So in a nutshell
