Steering rack gaiters
    Hi is there oil inside the gaiter, if there is does it come from power steering oil?? thank you Martin
    There shouldn't be fluid in any significant quantity, unless the seals are leaking. If you find enough to run out as a dribble then you might want to try one of the PAS leak stoppers/conditioners to try and stop it.
      Moved from Technical section
        As Russ says, there shouldn't be any oil in the gaiters.
        When I jacked mine up, oil came out of a hole on one gaiter (because of the angle of the car) - still not sure if it was damage or a deliberate air hole. Anyway, I peeled back the gaiter, emptied the oil and cleaned it all up and rotated the gaiter so the hole was at the top.
        Over a year later, still no sign of oil. Not a perfect fix but it has got me through two MOTs without needing to replace seals. Clearly, it is only a slight leak.
