Since my recent engine rebuild, one of the things on my snagging list is that the revs vary on idle within a few seconds it varies by about 100 or so revs. I believe the fuel mix is not too far out from the colour of the plugs. I have tried spraying wd40 in various places around the carbs and pipes and it doesn't seem to reveal any air leaks as far as I can tell. When the engine was first rebuilt I did balance the carbs using a borrowed syncrometer. However, in the absence of inspiration for anything else to try, I thought I might as well go back to square one. Has anyone tried this type of balancing tool
Looks a bit mickey mouse, but it's half the price of a syncrometer like I borrowed before
e.g like this
The carbs had new diaphrams, needles, floats, valves etc not all that long ago and I am not inclined/skilled enough to work on carbs beyond that. What I really need is a known good set of carbs to try a substitution test (i.e to be sure whether or not it is the carbs causing it), but I that's not the sort of thing anyone has knocking about unused.
Any other suggestions for things I could try or symptoms to look for or tests to do to help narrow down the likely cause ?
e.g like this
