Wasn't sure if to start a new thread as this is related to my "Hunting at idle" thread, but here goes.
I decided to go back to basics starting with checking the ignition timing. I found i was set to about 10 degrees BTDC and at that the distributor was turned about as much as it could. I could maybe force it a bit further but surely that cant be right ? It certainly runs much sweeter if I take the dizzy bolts out and turn it a bit further. So I thought the dizzy must be a tooth out. I tried turning the dizzy one tooth but it would not fully engage. I turned it two teeth and it would. Im guessing it will only engage every other tooth as there are 12 teeth on the gear but only 6 flats on the shaft. If I turn it two teeth (one flat) then it won't run at all. What is going on here. I can't seem to get the dizzy in a position where I can get to 12 BTDC.
